I just completed hooking up my 1987 johnson j90tlcur to my boat. Ran it on muffs. Strong tell tale coming out. Thermostats appeared to open because I saw water coming out of the slots after about 60 seconds near the top of the lower unit. Ran it in gear and reved it a few times and let it idle for a bit. Total run time was about 2 minutes 30 seconds. I touched the top of the block on the right side could only hold my hand there for 1 second. The left side about 3 seconds. I'm going to run it in a test tank tomorrow to see if it will run cooler. Don't know if the alarm works. How do I know what is normal?
