Re: Running in a "bucket"
Yup, if you have a bad fuel fitting, maybe it's as simple as that! Maybe its sucking some air.<br /><br />As for ignition things...<br /><br />I bought a '70 25 hp this spring. I pulled the flywheel to replace the points/condensers and found a coil badly cracked. The engine started and ran OK in a barrel as it was. My guess is that the coil would've started shorting and running poorly once it warmed up good. I replaced both coils and point/condensers... now I know the ignition should be OK for quite a while. <br /><br />If your flywheel has the 3 holes on the top, an automotive harmonic balancer puller, less than $20 from auto parts store, seems to work good. I forget what the threads of those holes are maybe 1/4 x 20 ??. You might need to pick up some bolts of the right size... It's a good time to start an "Outboard tools" tub if you don't have one already. Spark tester and compression gauge would be good to buy too if you don't have 'em already. And don't use a jaw puller from the edges of the flywheel.<br /><br />oh, and you can probably tell with a timing light without pulling the flywheel if the timing is way off (sheared key). But, my guess is you wanna pull the flywheel to check over the ignition anyway.<br /><br />I think it's wise to check compression before putting $$$ into an engine. Then at least you know where you're starting from. It would've been interesting if you had checked before and again after doing the decarb'ing.<br /><br />good luck.
