ottawamerc
- Joined
- Sep 16, 2004
- 128
Hi guys, quick run down on whats going on. It's a new to me 1987 Sea Ray 268 with a 260 Alpha 1, the engine was blown when I bought it so I had it rebuilt over the winter and after two test runs I'm not happy with the boats performance. It seems sluggish and will only put out 3200 rpm on WOT. The engine was bored out 0.30 over with new everything, plugs, wires etc etc. I pulled a few plugs and they seem pretty lean even though the boat only has less than 4 hrs on it so far. I have checked the fuel pickup and lines and they seem good and while the engine was out I cleaned the carb. I'm wondering if this might be a defective carb issue and the main reason why this boat is on its 3rd engine? On land with a hose connected it will run up to 5000 rpm no problem and the timing is fine but under load, no way! It has a 16X16 prop on it and I tried a 14.5X17 one too with the same result? I also have a Thundercraft Magnum Express 25' with the same engine package and that boat runs like a jack rabbit!
So any ideas on this would be greatly appreciated.
Scott
Scott
