running lean
thanks for the help in the past guys. How does one tell when the motor is running lean? (for future reference)
94 115 cross flow
tmcalavy
Re: running lean
If it's running real lean it will cough and maybe cough and die...kinda like a sneeze.
Dhadley
Re: running lean
To check for lean / rich at speeds above idle, hit the primer as you're running along. If the motor is lean it will pick up rpm (as you hit the primer) and then a split second later will start to blubber. A rich motor will blubber & lose rpm instantly. One that's "right" will do nothing for that split second and then blubber & lose rpm.
