I have been thru the Carb. on My 1989 Evenrude<br />and I think I'm going to take it to the boat shop<br />but I wanted some opinions so I don't get ripped off. First at Idle it seems to load up,has strong smell of gas (not raw gas like a leak)and when you try take off without revving it up a few times to clear it out it will cut off.It runs 5600rpm's. Now the real problem I pulled the plugs yesterday and they were dry and somewhat clean, I think it is running too lean (at least on top end)I'm mixing gas so I know it is getting oil.The compression is still the same 92lbs in all cylinders (low??)Could it be thee reed valves or the jets or carbs are still clogged? This motor has set for about three years before I bought it and has very few hours. I have run it about 20 or 30hrs since I bought it. Thanks
