thanks to this site i have tuned my 85-140 pretty close to what I think is almost perfect.but when i run it for a few min at 5000rpm then slow down and pull it into neutral, the idle will be around 1100-1200.then it will calm down after about a min,and idle back at 900.my fuel lines are all tight the bulb is always hard.I thought that i read here that if your running at WOT and push the primer in and it stumbles right away its LEAN? I dont remember.I've had jc4's-QL78YC's didnt make a difference.they both looked pretty clean.87 octane.how do I know if its running lean for sure?
