Re: Running motor out of water
How big is your motor? If it is just a small one, I would put it in a barrel filled with water. This will give it backpressure and give you a true simulation of being in the water<br />If the motor is too big for a barrel, then you must use earmuffs. The impeller is only rubber and it can only take a few seconds to burn it out
.Just remember that earmuffs do not provide backpressure so dont go to high with the revs.
