Running on Muffs
pogi
Hello again, I'm doing some trouble shooting out of the water and need to know about running on muffs. How long can I run the engine on the muffs and is it ok to shift into gear while on muffs also is there a max RPM. Thanks for the help.
dan t.
Re: Running on Muffs
I have run my alpha 1 and 350 motor 1/2 hour on muffs with no ill effects,I dont see why you couldnt run it all day. I have run it in gear and up to 1500 rpm, no problems
achris
More fish than mountain goat
As long as you have water running to the muffs, you could run it for a week... I wouldn't recommend more than 1500 revs. If you go too high, the pump sucks more water than is available and you end up with a dry run condition and damage the pump impeller. If it's late model V engine, then you also have a minimum of 1200 revs... ;)
Chris........
