Running on muffs
WOJO 1
Can you run a 15 hp on muffs or should it really be in a tank? I saw some youtube videos and they running them on muffs. Whats the scoop?
oldcatamount
Re: Running on muffs
Running on muffs is ok if all you want to do is start the motor and let it idle. It's not good to rev up a motor that's on muffs. If you want to really "test" the motor, it should be in a tank (or, on the boat in the water).
WOJO 1
Thanks Oldcat. Kinda what I was thinking. Flushing only.
boobie
You can put it in gear if you want to check your shifting, but don't over rev it. I do it all the time as that way I know it will shift when I get to the water.
