[FONT="]After wasting countless hours focusing on fuel issues and replacing/rebuilding everything in the fuel system in my 1968 Mdl 60 6 hp 2 stroke/2 cyl Merc to fix a chronic lack of power at WOT, all of which failed, thanks to Racerone, I think I am finally pointed in the right direction. However, I still don?t know exactly what is wrong. [/FONT]
[FONT="]I have spark at the plugs and to the plugs but, I?m not sure how robust the spark is in the upper plug; I have compression in both cylinders. [/FONT]
[FONT="]I ran it at about 1K rpm in my tank and pulled the top plug wire, nothing happened. I reinstalled top plug wire and pulled the lower wire, it stalled instantly. I repeated process, same result. Then, I switched the spark plugs. I repeated the process and got the same results which means that it appears to be running only on the lower cylinder just as Racerone suggested. This would indicate that the root cause could be the top plug wire, the top cylinder coil, or its condenser. [/FONT]
[FONT="]On the other hand, could a malfunctioning reed valve produce this same effect? In other words, could a defective reed valve prevent the air fuel mixture reaching the upper cylinder but work properly for the lower? [/FONT]
