Running on one cylinder
Kenny1
I have a 2003 Johnson 2 stroke that only runs on the top cylinder. I bought this boat as is. I have checked compression and both cyl. are 140psi. I installed new plugs. I used a spark plug gap checker and it jumps 7/16' gap on both cyl. I removed carb. cover and placed my hand over top carb. opening and the engine died. No affect on bottom carb.I squirted fuel in bottom carb. while cracking open throttle a little and still no affect. Both carbs have been rebuilt. I even swapped top carb to bottom with no affect. HELP
Bottom seal on crankshaft ?------Or cylinder sleeve out of position ?
Crosbyman
Not much behind the carb to stop the in rush of the squirted fuel / air mixture except the reeds
can you at least feel the air being suck in the lower carb during the compression stroke. (try a sheet of paper on the carb face)
compare it with the top carb inflow
could be bad/stuck reeds behind the carb I suppose or general loss of suction due to a bad seal as indicated by racerone
F_R
Broken reed valve???
EDIT: Crosbyman posted same thing at same time.
Kenny1
Hey guys. I removed the reed valves and they seal good. There isn't any suction on bottom carb unless I open throttle up and run at higher rpm. The suction is not as strong as the top carb. How do I check the crankshaft seals. I tried pumping up crankcase by disconnecting pulse hose and connecting a vacuum/pressure tester. Can not get any pressure in crankcase. I think I might have to pull head and have a look.
Was the piston at top of cylinder / bottom / do not know.----When you tried to pressure test crankcase ?-----Looked for holes / cracks in the crankcase ?------Inspected fuel pump ?------Does it still have the VRO pump ?
jakedaawg
Before tearing stuff apart you may consider hooking up 2 spark checkers Simultaneously to ensure that the spark alternates evenly...
Crosbyman
I must have missed something…. which motor model is it ?? 2003 johnson 2 stroke is vague for some reason
A 2 cylinder and 2 carburetor would make it a 40 / 50 HP model I think.-----Just guessing.
Kenny1
Can anyone give me the link and sync measurements for 2003 Johnson 50 hp 2 stroke? I think my spark control rod is way off.
