Re: running rich lost rpm on Wot
Don't know what motor you've got, but most "mixture" screws on carbs are idle mixture adjustments and have very little to do with Wide Open Throttle RPM's, which would be regulated with non-adjustable fuel jets. If your high speed carb jet is partially plugged with dirt, debris or fuel varnish, then that could cause motor to "lose RPM's".
