1978 55 Johnson <br /><br />I just rebuilt the carbs, checked timing and sync. replaced the prop. and I still can not get over 4000 rpms. The idle is lousey. Spark plugs are always wet when I pull them out and check them. Unfortuneatly the slow speed and high speed jets are fixed no adjustment possible. Compression is equal and 105 psi. New fuel pump. Do they sell smaller jets? Can adjustments be put on these carbs. Type IV? Can the reed valves/plates cause a rich acting problem? <br />As you can see I am at a lost for new ideas. The reason I believe it is rich is because the always wet plugs,large fuel consumption and when I ran out of gas a while ago, before it died it ran great for about 15 seconds. It also will not idle less than 1000 rpms. <br /><br />Any and all help or ideas woulld be greatly appreciated!<br /><br />Thanks Smitty
