duped
- Joined
- Aug 26, 2009
- 307
Hi, I have an idea that I was trying to gain some professional opinion on before attempting. I have a boat with twin 5.7l carbureted Mercruisers. My power steering is on starboard engine only, leaving me forced to troll only on that engine to keep my hydraulic steering system happy. (Unfortunately seastar specs I must use PS with this ram.)
I have hit dead ends on fitting a second PS pump to the port engine, the logistics of that is beyond my capabilities.
I have two side mounted 75 gallon tanks which each feed their respective engine ONLY. I understand there are fuel selector valves available that this boat unfortunately didn't come with, but we're talking a lot of plumbing there. Truly, all I really want is to run the STB engine off the port tank. I DONT need run the port off of STB or run both off one. When trolling, I run the port tank lower and have to refill it twice as often, and it would be great to balance the tanks.
Anyway, I know the factory fuel/water separators have two inlets and two outlets per engine. Is there anything wrong with my wacky idea of installing another fitting into the 2nd outlet of the port engine's filter housing to feed the STB engine? I'm thinking install a quality shut off valve right after the new fitting that I will turn off whenever the port engine is running (so I'm not running both engines on one 3/8" line), and then install another shut off at the line coming into the STB filter from the STB tank and be done? Anyone ever try this, or should I just suck it up, buy the selector and re-plumb everything?
