Limited-Time
- Joined
- Mar 30, 2005
- 5,820
00 350 MAG MPI SN 0L671793, seems to run hot 180 to 190 deg.(according to the gage). I plan on checking the engine temp with a IR thermometer to verify gage accuracy. I assume I want to check the temp on the thermostat housing next to the temp sending unit to get the most accurate comparison. Any thoughts. Both the impeller and thermostat were changed at the end of last season. Boat is operated in fresh water only.
