Re: running trolling motor battery down
[colour=blue]Some of the above statements are not correct.
Any battery has a finite life, it can be discharged and charged (that would be known as 'one cycle') up to 3000 times. Running a battery too low will decrease the amount of times it can cycle. A normal battery (AKA - shallow cycle) should not be drained below 80%. A deep cycle battery can go down to 50%, hence the name 'deep'.
All batteries should be fully recharged ASAP, a smart charger is the best option.
Flooded batteries DO NOT have a memory but the depth of the cycle DOES deminish over time, especially if they have been discharged below the minimum standard.
The chemical process that occurs inside a battery is called electrolysis.
