westhunt22
- Joined
- Oct 1, 2011
- 6
I have AD41B engines with the later style plastic air filter housings and filters. I'm getting some blow by, which coats the filters. First, I don't understand how that oil is getting into the filter housings, since it seems to be coming in from outside, and there is NO blow by hose going to the filter housings. And I've removed the filters and looked at the air side turbo impellers, and they are clean on both engines -- no oil). During recent trouble shooting of low power, I removed the filters, which needed changing, and ran the engines under load (i.e., took the boat out into the river an ran it). Performed MUCH stronger. I'm getting about 100 hours on the engines before the filters start affecting performance, and Volvo filters are stupidly expensive.
So, that begs the questions: If I remove the filters, but leave the filter housings in place, am I risking engine damage? The filter housings have slots in them, but not big enough to allow any large items (plastic bag, etc.) to get in, and the air in the bilge is quite clean. So, the filters are only catching blow by.
A follow up question: Has anyone found a different filter system -- K&N, etc... that would be higher capacity, and/or has washable filters or dry filters that I could substitute for the Volvos ?? (I'd be leery of oil soaked washable filters like the K&N, because of the likelihood of sucking the oil into the air side of the turbos).
Thanks for any help. And please remember -- these are diesels, not gas.
