1976 Chevy 305 OMC, EI conversion by previous owner.
Boat runs great for 15 minutes. Then starts to miss, run rough, backfire.
After a few minutes of that, will idle but not run in gear.
After a few minutes fo that, will not start.
Next time out, or even an hour or so later, everything is good again, for 15 minutes.
This problem appears to be time related, so what can change after 15 minutes? Not choke, choke is open as it should be. Not engine temp as engine is up to temp in a few minutes but failure is not until 10-15 minutes.
Had carb rebuilt, no difference.
Tried new coil, no difference.
Found out recently (I had never been into the cap in 4 years of ownership) that boat has EI conversion.
I am thinking of getting to cap and rotor, maybe plugs today, aven though I can not think of a time related problem with those. I polished up rotor contact last time it quit and it went for another 10 minutes, and died again.
