I have an 82 Evinrude 35 HP outboard that runs great for 5-10 minutes under a load (high RPM & Low RPM), then it will bog down and run at a very low idle. Won't die, but it won't power up like it should. If I turn the motor off and let it set for a bit I can start it up and drive off...for 5-10 minutes. Then the process repeats. It's getting fuel, the carb has been rebuilt. Seems like electrical but was hoping someone might have an idea of where/what to look at. I was thinking the power pack might be the cause???? Any help would be appreciated.
