Rust removal.🤯
64osby
We have started a rebuild of our 62 Land Rover. Rover's had aluminum bodies, no rust. The original frame and other parts are steel, some galv.
Saw a ytube video on rust remove with electricity. A tub of water, some laundry soda mixed in, a battery charger, steel wire and some sacrificial steel is all you need.
Super simple and it works great. Wire up the parts, hang them in the water and hook up the battery charger. Removes surface rust and deep pits, also will peel the old paint and junk off the parts With out loosing any of the good material. No sanding or chemicals and I can work on other things while the parts are in the bath. Parts come out with a black film that when dry wire wheels off super easy. Then I spray with rust reformer.PXL_20210705_164912669.jpgPXL_20210706_134206033.jpgPXL_20210705_163140823.jpg
I've also cleaned up some old tools, hammers, plyers, vice grips and sockets. Small stuff takes a few hours, Big nasty stuff has taken up to 36 hours. You can hang multiple parts at the same time.
Every so often the sacrificial steel needs to be cleaned back to bare metal.
I'll post some after pics once I take some.
I prefer the acid bath myself vs the electrolysis method. both can be found in the rust removal section here: https://www.stovebolt.com/techtips/
my last acid "tank" was a 4' x 8' x 3' high crate. I lined the interior with plastic sheet. did 500# of fenders and bed parts at a time using a 20:1 mix of water: muriatic acid. also did the cab bottom
when I finished the projects, i simply neutralized the patch
4 hours in the acid bath, 5 minutes with pressure washer (repeat as needed), then a baking soda water spray to neutralize followed by a phosphorous coating and epoxy prime
64osby
Here are some after shots.Screenshot_20210712-204213.pngPXL_20210712_235332770.jpg
The second shot is after wire wheeling, the first is after rust reformer.PXL_20210712_235413477.jpg
Here you can see where the rust has been removed but no good steel, that would happen with sanding or grinding
KJM
Thats pretty cool! that black painted part almost looks new!
64osby
Don't know about new but being 60 years old and this is the first time it was dressed up it is looking pretty good. Finish coats still to come.
I have many other parts that might barely pass for a template.
GA_Boater
64- Are you making a tank to dunk the frame or it doesn't need it.
64osby
Frame we picked up is in great shape. No need to derust. The only place that had rust was the steering relay tube in the front bulkhead. PXL_20210704_191653675.jpg
