rusted manifold bolts
kmongar
referring to the previous thread:
any recommendations for coating/sealing or painting the new bolt heads or studs/nuts to prevent or slow down the rust?
flabum
Re: rusted manifold bolts
Use stainless steel bolts and washers.
Shaun78
you can use stainless but it is a softer metal. I just painted mine and I will check them every season and if they look bad then replace them
Shaun78
I am going to grind the head off with a grinding stone on a dremel tool. How long should it take to grind down?
Lou C
Or smear em with marine grease, I use the OMC/Bombardier triple guard grease on most bolts and it works great. You could also use OMC gasket sealer, it stays pliable and can be used on thermo housing bolts ( used it as per the OMC manual, and they came right out, salt water boat, years later!)
Don S
See reply #8
Don S
Never seen how hot the exhaust manifold bolts get on a big block have you?
Don S
Using the formula below, you should be able to find the answer within a second or two of the actual grinding time.
JustJason
How did you get my families secret beer recipe??????????????????????????
You Swine!!!!!!!!!!!!!! :)
If you guys are that hung up on the bolts spray some mercury storage seal on them once every couple of months.... and let the stuff shake and bake on the manifolds until you get that crusty greasy goodness that forms.
Just ask yourself this....
"WWDSD?"
Lou C
I've used the marine grease on spark plug threads too, they get pretty hot, right Don?
I do recall your telling us not to use anti seize so there is not much left you could use.
Don S
Lou, it's not the threads that cause the problem, the heads of the bolts RUST off.
Don S
Oops, wrong equation! I changed it to the real one for grinding manifold bolt heads with a die grinder. :rolleyes:
Sorry, hope no one got the recipe:eek:
Lou C
I have seen that on friends' boats, the thing I wonder is what OMC used for the studs and nuts on my old 88, there is no corrosion at all on them, I guess they did one thing right!
Don S
There is a HUGE difference between your 4.3 and a 7.4.
The 7.4's were seriously bad with rusting manifolds and bolts. The manifolds would flake off big chunks right after the flange that mounts them onto the head.
A Lot more heat than your 4.3 will ever make.
flabum
most engine manufacturers do not use studs due to clearance problems. On dual engine set-ups and some singles, the engines can be so close that with studs, removing the manifolds would be impossible without removing one engine.
Don S
On the Big Blocks, the bolts (and studs) are short, not the long bolts and/or studs of the Small blocks.
bruceb58
I had the same problem. I just slid the manifold off as far as it could go and cut the studs with a sawzall. Then I used bolts when I put on the new manifolds.
Shaun78
One bolt head takes about 20 minutes to grind off with a dremel tool.
