Rustoleum Primer
redeye1962
I have a question for all Rustoleum users.
Would you use Rustoleum Primer on an aluminum boat by rubbing vinegar to etch prior to putting the primer on?
andyrmilwaukee
Re: Rustoleum Primer
I just used rusto self etching primer on an aluminum boat i am fixing up for my dad, seems to have worked pretty well, but the test will be time. not that expensive about 5 bucks a can and its a spray paint so it goes on fast which is nice
Ayuh,... Ditto that...
redeye1962
The only rusto primer I saw at HD did not appear to be self etching. I will check again but where else could I get it?
Woodonglass
Last time I was in Wal Mart they had some and so did Autozone
redeye1962
well I looked at the label and did not see self etching but it did say it was for aluminum and galvinized. I am guessing that will work. just have to finish the sanding first.
redeye1962
I put on my glasses and read the label of the primer I bought. It was latex so I brought it back and got the sprayable self etching for the bottom of the boat. I think for the sides I will try a different rusto primer because it would be expensive in a hurry if I tried the spray on for the sides. It was weird because the label said it was for aluminum and galvinized metals.
Just wet sanded with 320 and will clean and spray tomorrow. I do not think I will roll and tip when I paint, there are too many obstructions on the bottom of the trailer so I will see how the roll on paint will work and do a good job on the sides where it is easier.
redeye1962
OMG that rusto self etching is the best thing since sliced bread. I was able to spray upside down and it went on perfect. It had more coverage than I thought it would.
ezmobee
Yep. Glad you took back that weird latex stuff.
redeye1962
Me too, the problem is we put it on my sons boat......seems to stick pretty good but not sure what the result will be until it is back in the water.
