rusty flywheel magnets
Rowboat
I installed a new stator on my 175 sport jet and now have a sluggish acceleration and wot miss could rusty magnets be a problem thanks in advance Bob
DHPMARINE
Re: rusty flywheel magnets
Did you position the new stator in the same position as the old one ?That is,do the wires come out from under the flywheel at the same position ?.<br /><br />Also the stator has 2 pair of wires,as does the trigger.Do ALL the wires with a yellow band go to the same switchbox ?<br /><br />Also brown leads and violet leads are easy to swap,as they discolor with age and look the same.Either scrape the insulation lightly with a knife to check color,or open up the jacket covering the wires to be sure of wire color.<br /><br />DHP
Rowboat
Thank you DHPMARINE for the advice. <br /><br />The guy who installed the stator said that there was only one position for it to be mounted. Is that correct or should I pull the flywheel?<br /><br />I'm going to check the wiring myself today.
Laddies
Banned
The stator does not control the engine timing it only produces the electricity to charge the battery and power the ign. system the trigger is what controls the timing
Zamboni
I'd look at how timing was done after stator install-just fixed a sportjet 120 where I'll bet the certified merc dealer didn't have tower likage at wot when timing after stator install.<br /><br />Getting cold in Ontario to check this on water-and driveways tricky with sportjet-good luck.
Rowboat
Thanks for advice guys,checked all wiring from stator and trigger, looks good. checked TDC with dial indicator but didn't do timing yet because I don't know how. I will borrow a timing lite and read service manual soon. Any sugestions appreciated. Is timing difficult? Is it a dealer thing?
