Hi All-- can anyone tell me whether a 1998 50-hp two-cylinder Johnson engine has the SLOW feature? The engine runs like a champ most of the time, but on two occasions (latest one was today) it won't run at the upper end of the throttle;i.e., can't plane the boat, but engine is fine at hull speed. Today I thought I heard a series of quick little chirps from the control box when it balked.
When this happens, it sounds like it's not getting gas and runs rough--almost like one cylinder is missing--three weeks ago had it to the dealer who sold it to me used-- they cleaned it out and said there was a fair amount of gunk in the carb. Possibly it needs a carb re-build and I was planning on having that done over the winter. But could it be the SLOW system kicking in?
Water stream is strong, and we had been drifting with engine off for about fifteen minutes, started up fine, went to plane the boat and the characteristic rough running, etc. occured. Oh, and I don't run it from the main fuel tank--I exclusively use a portable tank and hose--both new this year.
Maybe I should just shut up and get the carb rebuilt?
Thanks,
Jeff
Thanks,
Jeff
