Robert Harris
- Joined
- Oct 29, 2002
- 30
Just got my 1980 Johnson 115 powerhead tore down to block.Lucky for me the crank looks good.Just a few questions I need some answers on.<br /><br />1) Had piston meltdown which caused damage to cylinder wall and head.Will be taking to shop to bore all four with new pistons.What has to be done to the intake and exhaust ports if anything? Also what about heads..one was chewed up pretty good from the bad piston.<br /><br />2) Is there really a difference between Wiseco or genuine OMC pistons as far as quality or performance.Will not be running that hard(it's on a bass boat).Is there a way to find out if these pistons are original by the part number on them?<br /><br />3) Crank bearings all look good from what I can tell.Should I replace anyways or just the seals and o-rings?<br /><br />Also, it was recomended by a dealer that I go up one size on my main jet and get the thicker head gasket.Can someone explain this to me?<br /><br />Thanks for the advice.I'm not experienced at all with this outboard stuff, but I'm elbows deep in it now.
