Sacrificial Anode Evaluation
mwnitz
Hi,
Everywhere I read, I'm told to replace my sacrificial anodes on my Mercruiser Alpha One stern drive when they get 50% worn. Does this mean 50% of the surface area you can see is covered in corrosion? Or does this mean 50% of the thickness of these parts wears away? Mine are completely covered with corrosion yet look pretty beefy. Any pictures to illustrate examples would be great too. Thanks!
Aviator5
Re: Sacrificial Anode Evaluation
50% of the metal volume. Corrosion should be cleaned before you put it in the water.
Rocky_Road
Worn means 'gone'!
But since these aren't all that expensive, you might want to replace it with a nice, new, 'pretty' one.
If this were mine, I would welcome the surface loss as proof that it was properly grounding...and working!
Just my opinion...worth about $0.02 American.
Happy boating!
Aviator5
I agree, I said they should be cleaned, but never actualy cleaned them myself, just put a new ones in the beginning of the season.
Rocky_Road
I like the idea of replacing them every couple of years, if only to insure that the mounting bolt doesn't end up 'frozen'...no fun drilling the bolt out!
Happy boating!
