Safe Glue for Fiberglass
GaBoy
What glues are good to use on fiberglass for a sure hold and no damage to the surface?
Boomyal
Re: Safe Glue for Fiberglass
Me thinks you are asking for an impossibility. Any glue that will hold will will bond with the surface.
sdunt
we need some more details here.. Are you installing new fittings or hardware to the boat? If so you can use 3M 4200 sealant to seal the bolt - screw holes (WalMart sells it)
http://www.iboats.com/3M_Marine_Adh...72021323--list_time.1181760705--view_id.39227
If you are really wanting to 'glue' something to the fiberglass but later remove it without any marks, that is near impossible. Mainly because wherever you mount this thing will not fade in the sun like the rest of the boat, and so you'll see where it was.
To stick things to the boat semi-permanently, use 3M 4200 and 3M 5200 if really don't want it to come off..
GaBoy
Instead of using screws in some areas down under on the inside, I had wondered if there was a glue to use that would not destroy or deteriorate the fiberglass. I had been told or read that be careful what you use.
ondarvr
There are very few products that would do harm the fiberglass and I don't think I have every personally found one that would. I don't think any glue a person could buy retail would have any adverse effects unless what you glue on was somehow torn off, then the better the glue, the more damage there would be.
