riptide09
- Joined
- Sep 11, 2009
- 297
I did a bonehead thing and let my son in law use the boat. He towed it with a questionable tow vehicle and dragged the safety chains. A bunch of the links are ground down half way through due to dragging. Needless to say I have to fix it now.
'03 FourWinns Freedom 170 with Johnson 115 OB. Gross Weight of boat and trailer according to manual is 3500 lbs. According to trailer registration gross weight is 4000 lbs.
Here on iBoats they have 2 ratings of safety cables in the correct length. One rated at 3500 lbs. and the other at 5000 lbs. I like the idea of using the coiled cables better than chains. Any issues with using the 5000 lb. cables instead of a set of chains. Seems to me they should be OK and within weight specifications for my application.
