Re: Safety Question: adding floatation
Don't want to step on JB's toes here, but if you feel this boat serves ALL of your other needs/desires well, I would not be so hasty to beat a path to someone elses door.<br /><br />Many boats that size do not have the foam floation, but can certianly have it added. AND... You are correct to be concerned about wiring access, etc.<br /><br />Adding the foam is NOT rocket science... Just requires patience, and more time to do now that the boat is already constructed, to get it right.<br /><br />Wiring access: This can be assured, by moving the wiring away from those areas, in which you want the foam placed. In those instances where that is not practical, simply install the wiring inside some el-cheapo (schedule 125 works for me) PVC plastic pipe. The PVC pipe is available at most home centers fairly priced, and is most likely to be found in the lawn sprinkler aisle.<br /><br />Ditto for fuel hose routings, etc. Simply find some light-weight plastic tubing of a diameter sufficient to provide an easy and reliable access to the critical items you want to protect.<br /><br />As for the foam, there are several "self-build" boat builder links and materials houses to purchase this stuff from. BUT... Check pricing first, as it can be a tad $$,and messy to work with, and you may just find it cheaper (or significantly easier) to let a professional do it.<br /><br />If you want to have someone else do the foam installation, you can save a bunch of $$,by doing the wiring and hose protective prep work described above, yourself.<br /><br />For buoancy calculations, to be safe, I'd use approx 7 pounds of buoancy added for every gallon (or 128 cubic inches) of space filled with foam.<br /><br />Good Luck, Obiwan
