sailboat nav lights
yonu
hey I know this is going to come out kind of odd but I need some suggestion on sailboat nav lights I know that I need a bow and stern deck lights but the mas lights kind of have me messed up as in what I need and how to go about installing them since the mast is taken down for trailering. If it helps this is for a American 16.
Thanks,
yonu
SolingSailor
Re: sailboat nav lights
If you have the red/green bow lights, and the white stern light already, the only other light you may need is a white light up on the mast, if you will be using a motor.
This information should be readily available on the web. Check out the Coast Guard website, or see what is called the Colregs, regulations for avoiding collision at sea.
yonu
ok thanks for some reason i was thinking I needed more than those 3 so I figured I would ask
16' your going to be out at night in that? kinda small to be out at night. i have a 16' and it does'nt have running lights. i would think a battery for it was be just to much.
yonu
Yeah a 16ft at night. I am planning a couple of overnight trips (I figure i have a 2 bunk cuddy I want to use it)and am planning to use led bulbs and a 9ah sealed battery based on current draw it should give me at least 8hrs lights.
Thanks,
Yonu
o ok you have a cuddy i thought you had a open cockpit that's what i was confused about
yonu
Oh i would not even try it with an open cockpit no weather protection and sorry if my last post made me sound like a jerk
Yonu
doehunter
a sailboat with a motor running is a motor boat.
Under 26 ft, the minimum you need is a red/green on the bow, and an all around (360 deg) white on a 4ft pole on the stern. Just like a 16 ft skiboat would have. You don't have to have a mast light(called a steaming light). The all around white on the stern qualifies for that. Do it on two switches though because if you anchor, you're supposed to turn off the red/green running lights. If done with all LED light's you won't pull squat for amps and a smallish battery will do, but PERSONALLY, I'd have to throw in a stereo, and more lighting for camping, so I would carry more battery!
Good luck, I just started overnighting on my sailboat too and having a good time.
Jim
