Salt water in old rude worries
alumachris
i have a 1968 18hp evinrude that has been run in salt water several times when it did not get flushed with fresh h2o afterwards. what kind of damage could occur and what can be done about it?
Thanks in advance. you guys are always a big help.
Chris1956
Re: Salt water in old rude worries
Those old J/Es were never recommended to be flushed. If you plan to use it in saltwater regularly, I would flush at the end of the season, and not worry about it in between.
F_R
Don't be fretting about it. Give it a good run in fresh water. Water is the solvent for salt, nothing else is needed. However, nothing will disolve the aluminum oxide corrosion once it happens. At least not without disolving the rest of the motor too. But a few times isn't going to kill it.
