Re: Salt Water
Hi Mark. Any boat can be run in saltwater, if proper precautions are taken. You'll need sacrificial zinc anodes on both the hull (if it's a tinny) and on the out drive to prevent corrosion. You'll also need to thoroughly rinse out the motor using muffs after every saltwater run. Any non-stainless steel fasteners will also rust much more quickly in a salt air environment, so be prepared to address that issue as well when the time comes. For these reasons and others, I/O are generally going out of favor down here in favor of large hp outboards which are purpose built for saltwater, are easier to maintain, and weigh less. Removing the I/O would also free up quite a bit of space in the boat as well. Of course, you would need to rebuild the transom and mount the OB, but that's not too bad and would still cost less than a new/another boat.
