Saltwater Fishing
mcconnell63
Has anyone occasionally use there Lund boat in saltwater and did you wash it off when you got home. Does the saltwater have any effect on the aluminum or the rivits. Thanks, Al
NWLundguy
Re: Saltwater Fishing
I just signed up to this forum so I could respond to your question. I am a diehard Lund customer and live on an island in the Puget Sound (WA). I have never owned anything but Lund and am now on my fourth boat since 1981. Just purchase a new WC-14 last month. I only occasionally use my boats in fresh water. I just sold my trusty 1999 17 foot Prosport with Yamaha F100 because I couldn't keep ahead of the blistering paint. When a freshwater boat owner occasionally makes a saltwater trip I don't think it is a long term problem because you are going to dunk it back into fresh. I was always meticulous about cleaning and rinsing but it is chore. The unpainted Lund skiffs do well on saltwater because they aren?t painted on the bottom so the metal can be cleaned. My first boat was a 1981 S-14 that was exclusively used on salt water in our inland sound for salmon fishing. In 2001 a local guy purchased it and he is still setting crab pots every summer; I see him at the boat ramp. I also wonder about salt water getting in between the double plate hull on the larger boats like my Prosport. Again, if you spend most of your time in fresh water the boat will get rinsed and there won?t be long term problems. Around here many of the hard core salt water fisherman use welded aluminum boats that are largely unpainted; only on the topsides and interior. Lund uses the best aluminum available but once the corrosion starts to bubble under the paint around the rivets it is impossible to stop. Paint stripping, bead blasting, acid washing, alodine, and painting is a lot of work; I?ve done it on my Prosport several times.
Freshwater boaters have it so easy? go boating and put it back in the garage at the end of the day without a major rinse and wash project. This is the reason I went back to a Lund skiff for the time being. A simple run out to the mouth of the harbor to set crab or shrimp pots is not going to be a huge project because the small skiff is quick to rinse out. My wife is already grousing about not having a bigger boat so I?ll have to replace the Prosport before too long.
Sorry for the long post.
Brian
Bainbridge Island, WA
Mas
I've got a friend that lives on the saltwater. He got an aluminum ladder the is dunked twice a day by the rising tides. The ladder has been there over ten years and has little corrosion...to my amazement!
I would rinse your boat after every use & I think you'll be fine. I use my lund on the brine and have not had any issues.
MAS
mcconnell63
Thanks for the info Lundguy. My wifes cousin in Conn. wants to buy a new self bailing fiberglass boat and right now he has an '07 28 or 30' GW with two 150 Yamahas and a '07, I think, 16' Alaskan SS with a 40 Merc he wants to give me. He always used it in saltwater but he takes good care of his stuff.. I never had an aluminum boat, only wood or fiberglass.. <><
mcconnell63
Laker, Thanks for the info. I was Air Force E 4, only stayed in for 4 yrs , should have stayed for 20. Now I'm a DV Nam Vet. Could of been worse. <><
Pat Curtis
MAS
That's because salt water alone does not corrode aluminum. It's oxidation coating protects it (think of the Statue of Liberty's copper) from salt water's neutral PH level.
Aluminum is susceptible to galvanic corrosion though (usually from copper or steel...again think of the Statue of Liberty..but this time I'm talking about the steel frame contacting the copper exterior). Since the ladder is out of the water quite often, the ultra slow galvanic corrosion would take even longer to yield signs of corrosion.
Mas
Agreed...that's why the rivets should also be aluminum...to reduce the possibility of galvanic corrosion.
MAS
