saltwater in lower unit
dhughes49
I went to check out a used boat with a 1996 johnson 150hp saltwater moter
and found water in the lower unit. the owner put the boat in the shop to have new seals installed . is this a deal killer :confused: The drain plug had no metal shavings on the magnet. there was a tiny amount of super super fine particals that i would expect from normal wear and tear. Other than that the boat checked out great i really would like to buy it. Should I walk away or stay?
JB
Re: saltwater in lower unit
Water in the foot should not be a deal breaker, dh. The most common cause is re-use of the gaskets under the Drain/fill and Vent plugs, but if the seals are bad they will soon be replaced.
Walk away or stay? That depends on a lot of other stuff.
Good luck. :)
dhughes49
thanks ancient so r u saying that getting saltwater into the lower unit is not a death sentance for the lower unit. The owner is having all the seals replaced.
stylesabu
i would be more worried about what salt water has done to rest of the motor. getting fasteners apart can be very difficult
