Same old problems fueling
Maps
It's just impossible to fuel my boat at the dock cause of the back pressure . The vent line is ok. The problem is with the orientation of the inlet that's situated at the begenning of the gas tank . I can't find the right position .
Last year I tried blowing air in it with a straw. It worked a little...
Falty design , the dealer is not to blame.
kenmyfam
Re: Same old problems fueling
Is there no way to add another vent ???
Snobike Mike
Is your boat a 200 or a 210?
Mine is a 210 and while the inlet is a little awkward I find it works fine. Every once in a while I get some back splash but I just let off on the fuel hose, let it settle down and then get back at it.
kenmyfam
Mine fills no problem but it is just a baby with an "in floor" tank.
Maps
I have the 200 , they all seem to have the same problem. The 2 first years where fine but the last 2 were horrible at fueling . The inlet seems to loosen and rotates inward kinda . Bad design . The trick is to find the best orientation for the pressure to be released .
Maps
Blowing in the inlet with the use of a straw releases the back pressure wich helps fueling . Just be ready to get your face clear of that pressure when it comes out....AND NO SMOKING WHILE FUELING !!
