Pulled the risers on my 15 year old 243-hour 4.3 GL yesterday to get a baseline on their condition. Good news is, they looked great! Bad news is, I have a little bit of sand in the exhaust manifold now.
I had to use a real fine grit sandpaper (felt almost like emery board, but it was sandpaper) to prep the gasket surface on the manifold and when I pulled the rag out of the exhaust tube of the manifold some sand granules fell down inside the exhaust tube - not much at all but there was just a little and the sand was not much bigger than dust particles with maybe 2-3 that were slightly larger but still pretty small. I was short on time so I pushed ahead and reinstalled the riser (didn't have a vacuum handy). Now I am thinking I shouldn't have done that. To be honest, I am not sure if I have a vacuum that would pull them all the way up out of the manifold or not.
On one hand, I think they will probably blow out when I fire it up, and or not be a real issue. On the other hand, what if they don't blow out and find their way into a cylinder? What do you think I should do? Really don't want to redo all the work I did and shell out cash for new riser gaskets again for something stupid like this, but if there is a high chance it is going to trash my engine then I will do what I have to do. What should I do?
