Sanding between primer coats
redneckn
What grade of sandpaper should i use between primer coats.Using interlux brightside primer sprayed on.Body work came out good just need to scuff I guess.Been all over interlux's site and can't find any info.First time boat painter btw
D
DJ
Guest
Re: Sanding between primer coats
redneckn,<br /><br />If spraying, about 220.
redneckn
Thanks for the info .Scuff dry?
D
DJ
Guest
redneckn,<br /><br />Best to wet sand.
crab bait
an watch out... primer sands waaay to easy.. alittle sandin' goes along way... alitte to much,,, an you'll sand right thru it...<br /><br />but no biggy... just shoot more primer...
