Sanding bottom paint (easy question)
dcartie
Looking to save some cash and do my own bottom paint. Anyone know where to get one of those big foam sanding blocks in the 80/100 grit? I can't find them anywhere. The paint is in decent shape so I'll be able to do it quick and by hand. And I'll be rolling the paint on....what roller should I use, rough wall or smooth? Hope this is an easy one. Thanks!
zool
Re: Sanding bottom paint (easy question)
What you want to use is a block that holds sandpaper, not a granular block like for drywall...you will go thru a bunch of paper....
Embee Sanding Block 40
If you want something longer, you can use something like this .
Rubber Sanding Block 05520, 3" x 8" at National Tool Warehouse
Then theres the auto body fairing blocks in many sizes...but for a boat bottom, especially if its for anti fouling paint, the smaller ones are fine.
Dura-Block AF4409 Black Long Sanding Block
dcartie
That's what I figured, thanks. Some if the other captains just use the small block if the bottom paint is in decent shape...makes for
A quicker job
vetting
Also, if it anti-fouling paint, the paint that comes of is really hazardous, so wear a good mask and take the necessary precautions.
tpenfield
Highly toxic, that anti-fouling paint . . . otherwise, it would not be anti-fouling :D
A good respirator style mask would be the thing to have.
dcartie
The respirator is on standby!
