Re: sandpaper heads
Sometimes I think gaskets work better if the machine surfaces have a little tooth to bind to but I admit I'm no mechanic, but my Grandfather was a machinist. LOL. Anyway, either way will get the head done in the end I believe. Rick.
This is an interesting thread, but probably one that would never see a consensus reached.
There is a lot of theoretical arguments that can be offered up, but IMO, for most of us in here, the practical takes precedence.
If it works, in spite of theory.... it still works! Smile and wave boys, smile and wave....
Given that a surface finish measuring device costs $1000- plus, for even an entry-level unit, it is unlikely to be found in many of our tool boxes.
Regarding "a little tooth...", the flip side of that says that if the head bites into the gasket, any lateral expansion ( likely to be at a different rate than the block mating surface) may work small tears into the gasket over time which can lead to failures.
My gut feeling would be for most O/B heads that 80x would not necessarily be too coarse....and 600x not too fine. Between those values is probably a safe range.
