Re: Sanity Check setting timing on '98 3.0L
I just rebuilt a 2007 3.0 without consulting the service manual, so I may not be the best source of info. Mine needs to be set at 1 or 2 degrees BTDC, I believe, but I will have to check to be sure. Anyways, I had to slide the distributor into the block, but before I did, I set the #1 cyl at TDC on the compression stroke (right after the intake valve opens). i varified by opening the valve cover. I alligned the gears so that the rotor was pointing to the #1 wire on the cap. I then had a friend bump the key so the distributor would slide down into the slot in the oil pump important, (lol). I then alligned the mark on the block with the mark on the distributor. She fired up and ran smooth. I just twisted her slowly back and forth until I found the right idle RPM, 750-850 on the driveway. Of course I waited a minute or so and I plan on rechecking her with a light and the right specs. I was able to get away with this because the valves were never adjusted during teardown of the motor and I had just adjusted them prior to spinning a bearing. I also never messed with the freshly adjusted carb. I sea trialed her and she sang like a song. I am intersted in checking her with the light and the correct specs (lol).
