I have just dropped the lower unit on a 1975 85 HP for the first time(my first time). The seller assured me that the motor was only run in fresh water. There is a build up of powdery white stuff that is on just about every surface. I am assuming that it is just built up aluminum "rust" (I don't know the term for oxidized aluminum). Could it be a mineral build up like calcium?
Should I try to remove as much as possible or not worry about it? My only worry is that some may get pushed through the cooling system, but it is small particles and no large chunks.
Should I worry about a similar build up in the power unit?
