Scan tool connector location for Mercruiser?
homelite
Re: Scan tool for Mercruiser
You need a scan tool, but not the computer software and a laptop. The Mercruiser scan tool from Rinda is about the best for the price you can get. Takes a little longer to use than the computer software, but the learning curve and price is a lot less.
http://216.230.203.183/marine/mtspec.htm
Don. I have this Rhinda tool. I am very familiar with using it. I just bought a 2007 Sea Ray with a 350MPI Magnum. Where is the ALDL plug? I quickly looked for it with no luck!
Thanks.Scott
you know Don passed about a decade ago.
look on top the motor
It's either near the ECM or the thermostat housing.
It will have a plastic cap over the DLC connector
homelite
I have a 2007 350 Mag in a Sea Ray 24' Sundeck. I cannot find the aldl connector. Very embarrassing because I'm an auto technician, have the Rinda tool, but I can't find the dang thing! Any advice is appreciated. I read where it should be around the oil filter but it's not there.
Bt Doctur
If it`a a FI or MPI look near the port riser just in front of the ECM
Look for a metripack connector. Doesn't look like any ALDL you would be familiar with as an auto mechanic
In fact, other than righty-tighty, left-loosy and SSBB and base engine hardware, there is very little commonality between your auto mechanic background and boats.
