Scott Mcculloch / Wizard 10 hp
Tech Tony
Well, I'm about done. I've been trying to get this thing to run right for nine months now. I took it out today and it idles perfect, but when I try to go full speed it takes awhile ,. Like 30 to 45 seconds to get on a plane. And it sounds like it's on one cylinder. I changed the coil, and condenser, and ignition has been ruled out. I noticed is oil and gas coming from either the reed plate gaskets or the gasket where the shaft goes into the leg. It's not a lot and the scews and bolts are tight. I had to make every gasket for this motor, including the head gasket. I'm done. The parts situation is why. If I take anything apart again I will need to make gaskets again. I am considering selling it. It is close to being right. But I don't have time to fool with it any longer. Mabye someone with more knowledge about these motors can get it going. My name on eBay is welder1965tony,. In a week or two it will be for sale on there. It will be a reasonable price. Thanks all...Tony
