Screws vibrating loose
Is there something that folks use to keep screws from vibrating loose on your boats? My fishing boat has lots of carpeted panels that are screwed into the wood subfloors. These eventually work their way out. I tried to use some Loctite that I had laying around but since it's not metal to metal, it didn't hold. A little glue? What do other people use?
jhnmdahl
A few options - you could try an epoxy if you want to stick with cementing the screws into the wood, but lock washers may be a better bet. The best long-term solution is likely to put a threaded insert into the wood, and then screw into the insert.
John
robert graham
The screws that hold down the composite decking in my jon boat get loose, especially after rough water crossing.....I tighten each one down(Phillips Head Screws) and put a drop of super glue around the edges of the screws....works pretty good...but they still loosen some with time. Not a big problem...just keep a Phillips Head screwdriver handy in the boat.....
My 2 cents: get a tube of Loctite PL Premium (construction glue). Put the tiniest dab on the screw threads... it'll hold until the next ice age.
Thanks all. I did do some outside reading as well and heard good recommendations about using regular old marine sealant. I've already got a tube of that so I'll give it a try next and then work towards some of these other options if needed.
frantically relaxing
In 2009 I repaired the back part of the roof on our SkipperLiner. Not wanting it to leak any more, and needing a temporary fix I bought a 12' x 10' sheet of black EPDM rubber. I asked the roofing supply guy what I could glue it down with. He had no idea, but suggested construction adhesive. So I bought a couple of tubes of this:
-- I ran a bead along the top edge of the rubber, and smushed it down evenly between the rubber's edge and the roof. Now, the roof was hardly 'prepped', as there's remnants of 3 different carpets and their glues. I didn't really care, this was just "temporary". It set up nicely, and I covered it up with some new carpet.
It worked so well I tried it to repair a broken fitting on the top of the 52 gallon water tank down in the basement.
6 years later, the glued edge looks exactly as it did on day 2, still completely glued down, no cracking or shrinking, and it's still slightly pliable, not hard- totally leak proof. And it's totally out in the weather, 24-7. The carpet isn't glued down, and many of the glue edges are always exposed. Same results with the water tank, even though silicone won't stick to these tanks, this stuff seems to! The repair has never leaked...
I haven't used it for holding screws, but I can't think of a better stuff to try! And since it does remain pliable, you'll be able to remove 'em too!
dingbat
Don't waste your money. Any old bath and tile caulk will work. What do you have out in the garage?
