That scupper is a drain hole for the cockpit (the area where you stand). It lets any water that splashes in flow back out automatically while you're moving.What is the scupper for that is at the bottom of the transom on a 2009 trophy.
lemme guess: Drain for a bait well, or built in cooler, possibly a deck drain on center console boat. Surely don't want backwash filling them up.
Then you'd guess wrong lol (on all counts). Key West (at least the older ones) deck scuppers drain below the water line with flapper check valves in place (you might have noticed that if you put your glasses on) and a significant high to low hose run. Ain't had a problem yet, so long as the rubber is good.lemme guess: Drain for a bait well, or built in cooler, possibly a deck drain on center console boat. Surely don't want backwash filling them up.
