bigmikek
- Joined
- Jun 18, 2013
- 79
I have discovered a leak in my bellows on the port side. A mechanic friend of mine says I need a
Transom Seal Kit.
I would like to order the necessary parts. This leak could be from last year and I am sure that it is the cause of some water coming into my hull. Not terrible amounts but it explains where it has been coming from. The boat seems to be operating fine other than this. ...... for now
But I have quit running it in the water until it's fixed. Can somebody please tell what I need from this page on iboats?
http://www.iboats.com/Mercruiser-Tr...3056737--session_id.115280612--view_id.269626
My questions are what ALL do I need to order to take off the outdrive, replace all bellows and hoses inside this area and put the outdrive back on?
Do I absolutely always need to replace the gimble bearing and U joint if they have been in a water environment? I would need a special tool to pull the old one out.
Thank you!
My Boat 1989 17.5 ft Glastron Sierra
Engine MERCRUISER Alpha 1 3.0 Liter GM 181 I/L4 SN 1A009382 mfg 10/09/2006 mod # 4111221UT
Outdrive SE106 Alpha 1 Series 1
Transom Seal Kit.
Thank you!
