Sea Camper 1970 with 225hp with OMC outdrive
Seainn
I recently purchased a Sea Camper that has been used in fresh water. I need some assistance on the OMC out drive. When I depress the switch down the lower unit goes down. When I activate the switch up it need some assistance by pulling the out drive up. I have used jumper wires to work the solenoid. I have two brand-new batteries and the power seems to be more than sufficient to operate the motor. The motor seems to be not strong enough to run the drive out (up). Could it be that the motors to leak or is there some other problem. Looking for help, if anybody has had any experience please help me out, thank you Jerry at
Re: Sea Camper 1970 with 225hp with OMC outdrive
Ayuh,... Welcome Aboard,....
Is the problem with the hyd. trim, or the mechanical tilt,..??
I don't know squat about 'em, but I'll bump this back to the top for ya....
Btw,... Delete yer email address,...
It's against forum rules, 'n the mailbox will be Full of spam in a few days, from scanning webbots...
Howard Sterndrive
pop the rubber caps (steering bumpers) off the trunnion caps -you'll see a grease fitting under there- grease those trunnion bearings and retry
