sea drive conversion!???
Status
Not open for further replies.
Bogart
Having problems with my 2.7 looper it,s a 87<br />It was rebuilt with several diffrent motors!<br />225 3.0 and so on! It's never been right!<br />I dont have the $$$$ To remove sea drive glass the transom put a new motor on it! 15000.00<br />upgrade! ouchhhhhhhhh. so heres my question<br />what would it take to modify a 98 225 ocean runner to fit the sea drive bracket!!!????<br />I saw one in my marina once! and know it can be done! A friend is repowering and will let me get his motor for 1000.00 with only 300 hours! this seems the way to go for me!!!<br /><br /> Help Bogart.
willxuout2
Re: sea drive conversion!???
It can be done. I have a 1987 2.7L sea drive bracket with a 1996 Evinrude 225 ocean pro mounted to it. They removed the original motor trim and tilt & motor mount. They then used the original sea drive controls.<br /><br />Most mech won't mess with it. Find an OMC mech that worked on the old sea drives and he may be able to help.
willxuout2
BTW, consider removing the existing sea drive bracket and mounting an armstrong bracket in its place. single application is about $1000. you can mount it yourself and it should cover the hole left by the sea drive. mount the "new" $1000 motor and replace the controls (if necessary).<br /><br />You may have about $3000 in it when finished.<br /><br />Something to think about.
Bogart
Armstrong Bracket!?? does any one have info<br />If the bracket covers all the seadrive holes!<br /><br /> Thanks Bogart.
Bogart
anybody else with info putting on an alternitive motor with sea drive bracket????<br /><br /> Bogii.
BrianTindall
OK I'll give you the scoop. Go to ebay and search for outboard bracket. Bought one from Marine Parts Wharehouse for $695 plus shipping. Nice guys to deal with. Now, I looked at one locally and really liked it. To make a long story short, blew one of my 120hp engines, sold them and bought an '88 3.0l Seadrive for $cheap with a new powerhead, got another '84 2.6l Seadrive for real $cheap with 400 original hours on it. After serious thought about Seadrive parts availabilty, I decided to buy an '88 J225 (3 year old powerhead). Since the main part of the '88 Seadrive will work with the Johnny, I went the bracket route. Your engine $1000, bracket about $800, sounds like the way to go huh?
Status
