Sea Foam
In quite a few posts in here, there is a reference to a product called SeaFoam. Is that an American name brand of carb cleaner or just a slang name for another product?
MH Hawker
Re: Sea Foam
Its a American made product and it was originally made for OMC
82rude
Re: Sea Foam
sea foam has been around since the 1930,s .nowhere on their site do they say it was made for omc.it is a generic cleaner used on and for many applications.
roscoe
Re: Sea Foam
It was not made for OMC.
It was developed privately, then later it was endorsed by Evinrude.
From the Seafoam site:
""Evinrude Outboard Motor Co. heard about Sea Foam and tested it for a full year and endorsed it nationally.""
boobie
Re: Sea Foam
So are you saying BRP Engine Tuner and Seafoam are the same product ?? Never used Seafoam yet,
Re: Sea Foam
We have Napa up here in Canada over yonder past those few igloos so I will try there and see if they carry it here. Thanks for the feedback:)
Sea Rider
Re: Sea Foam
Probably same carbon cleaners & inhibitors with different fancy names, Sea Foam is mixed with gasoline inside tanks, Engine Tuner is sprayed with engine on to clean, remove carbon deposits inside engine, mainly piston rings, exhausts. Must be used at each 100 worked hours if boaters don't regularly use Sea Foam or non at all.
Happy Boating
robert graham
Re: Sea Foam
Google: Marine Fuel Additives for lots of info...MSDS is a Material Safety Data Sheet will give most ingredients for various products. Most are naphtha, stoddard solvent(thinner),amines, alcohol, a few others. Sea Foam has been around a long time and is pretty well accepted as a fuel stabilizer and to prevent/remove carbon deposits...Good Luck!:)
WIMUSKY
Re: Sea Foam
You can find seafoam just about anywhere. Even at your local gas station. The key is to find it at the right price. Around here I see it anywhere from $6 - $11/can. Anytime I can get a good price I load up on the stuff. Been using it for yeas. I use it in every thing I have that has a piston(s)...... :)
roscoe
Re: Sea Foam
Seafoam is regularly about $48 a gallon at Fleet Farm, goes on sale for about $44 a gallon once or twice a year.
boobie
Re: Sea Foam
We don't have any Fleet Farms in Fl, but I know who you're talking about. Been there.
Re: Sea Foam
Thanks for the help and replies to this post. I have since purchased seafoam and found it to be a excellent product and when you are using it, a very good mosquito deterrent . Your help is much appreciated
Texasmark
Re: Sea Foam
Use it it works. Learned about it on this site and haven't been without it for the 9 years since joining.
Mark
kfa4303
Banned
Re: Sea Foam
+1. Seafoam is a good thing. Sure, it'll make your old motor smoke like crazy for a bit, but it should be much happier afterwards. I even use it in my old Ranger pick up truck with good effect. Just warn the neighbors so they don't think you're house is on fire!
