Some of you may have seen my previous posts, discussing my progress rehabbing a '63 Sea King 2 cylinder 5hp.
To date, I have replaced all the ignition parts (points, condensers, coils, plug wires, plugs). Thanks to NAPA!
Dismantled and cleaned the carb, blowing out all the holes.
Drained and resealed the lower unit.
In my test tank ( a large wheeled trash can) I tuned it up and was happy to find it actually reacted to slight adjustments to the low and high speed knobs.
In the test tank, with prop on, it ran really well, with the rpms up very nicely.
So I took it out to the lake and installed on my 13 ft aluminum fishing boat.
On the water the engine will not rev up anywhere near its potential. In neutral it revs fine, just like in the tank, but when underway it seems like its only running about half speed.
It idles great, runs and accelerates smoothly from idle to wide open throttle, it just doesn't want to run at higher rpms.
Don't have a tach to check it.
Would this be a link and sync issue?
Or too aggressive a prop pitch? (It's a 2 blade prop and likely the original)
Or too heavy a boat?
I put my Eska 5hp 1 cylinder (3 blade prop) on the boat and it ran wide open with no issues other than noisy and vibration.
Any thoughts would be appreciated.
Thanks for a great forum!
